TwinTurbo.NET: Nissan 300ZX forum - Try making sure connector to ECU is tight.
dvice
on February 25, 2014 at 12:41 AM
Code 21....out of ideas.
posted by The Sixth
on February 24, 2014 at 10:06 PM
As in, take it off, put it back on smoothly with even pressure, and holding it down while you screw the bolt in.
The Sixth
22:06:17 02/24/14
Try making sure connector to ECU is tight. -
dvice
00:41:46 02/25/14
Re: Thanks....done a few times already. (n/m)
The Sixth
10:12:18 02/25/14
You did not mention anything about Injectors
Cjw3
21:50:57 02/25/14
I got a used new style complete drop in from Woody...
The Sixth
09:47:28 02/26/14
Injectors are 100% deff good and working :)
Woody75 (Denver)
16:03:41 02/26/14
Didn't even need them, since I used a 95 harness...
The Sixth
16:17:09 02/26/14
Code 21 is calling it a PRIMARY wiring problem
Cjw3
20:23:24 02/27/14
Thanks for the input...
The Sixth
09:26:23 02/28/14
Where is the ECU that was in the Chassis?.. (n/m)
Cjw3
21:24:19 02/28/14
I've just got the single ECU...
The Sixth
10:54:29 03/03/14
